Paul Austin
Active Member
Hi All
Just started fitting my wing tips got the right one fitted and the trailing edge was not aligning with the aileron when in the neutral position so i split the trailing edge as others have done which alowed me to get the inboard end aligned but now the outboard end is still not aligned with the trailing edge.If i run a straight edge along the aileron past the wing tip at the trailing edge i can get the inboard end to align but the out board end is still about half inch low.Has anyone else had this problem and how have you fixed it ???![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
