Or you can have the look of rivets and the ease of removal by using piano hinges.
I have installed mine with hinges. Easy removal, looks cleaner, IMHO.
What a beautiful job , I think I'll use your method . Any piano hinge works for it ? If you have some details about the way you did that job, I would appreciate...I'm kind of partial to the hinge method.
Hi,
As usual, when I have two options I can't decide wich one is the best to me. I am hesitating between riveting the wing tips to the wing, or install K1000-06 to screw it. could somebody help me to make my choice?
We were going to rivet ours, but decided to use screws. It was some extra work, but after "final installing" the wing tips, and then immediately removing them two times after that, I was glad we used screws.
