Scott Hersha
I am past the point where I need to attach my outboard leading edges to the wing on my RV14 kit. What have you other builders done to enable you to do this? A normal wing jig arrangement works for the wing root, using the spar stub as a holding, but what about at the tip? What kind of an apparatus have others used to hold the wings for attaching leading edges, fuel tanks, bottom skin, etc? Pictures would be helpful.
