CharlieWaffles
So I built my wing cradles today and was looking through the wing plans and see that in section 13 (Main Spar) it says the spar will sag under it's own weight. But then in section 16 (top wing skin), it first mentioned the craddle/straddling of the spar. But it doesn't look like the spar has been reinforced before then. Does all the early drilling/prep work (sections 13-15) need to occur on a work surface that is fully supporting the spar or can all that work be done in the craddle with 2x4s on both end (no carpet roll yet)?
