Can someone who has easy access to their wing spars measure or at least estimate what their bend is on the outboard side of the spar? I noticed that one of mine (upper) appears to be less than 90 degrees and am already in contact with Vans but before I make a big deal about something trivial wanted to have someone else cross check. Are all of yours consistent?
Ken (vans) says spec is around 92.5-93 degrees and just putting a square across the top of one spar yields less than 90 degrees on this one spar in particular. Not sure yet how big a deal or not that is and I would think it is fixable.
Hopefully the semi-blurry photo helps explain.
QUICK UPDATE: Ken mentioned that the reference for the 92.5 degrees here is not what I am measuring potentially. It is the forward face of the flange right at the bend point which is not what I measured. I will go back tonight and do it again. NO need for concern![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![350umh0.jpg](/proxy.php?image=http%3A%2F%2Fi62.tinypic.com%2F350umh0.jpg&hash=1e1b91857feb2dac176f81e9c9fcdcb5)
