bobmarkert
While inventorying my wing kit I discovered what I thought was severe damage to the spar. I sent some pics to vans and they said it was from a grinder used to remove a scratch and was OK! If that is true I was waaaaaay to paranoid about smoothing the edges and lighting holes when I built the tail! I am considering buying a dye penetrate kit to check it further. Are there any issues with dye penetrate reacting with the anodized coating? I still can?t believe this is ok, so how about a second and third opinion from you guys.
If I did this correctly, click on the link below to go to the pics then use the arrow at the top to step through the pics
http://picasaweb.google.com/Bobmarkert/Wings/photo?authkey=a4AB0jpV24s#5208609166634562322
Bob Markert
RV8 slooooow build
N747BM
303 882-7410
Littleton, CO
Bob Markert
RV8 slooooow build
N747BM
303 882-7410
Littleton, CO
