Has anyone tried small "u" rubber channel, say 1/32" for the wing/fuselage fairing instead of the foam, and has it worked? Thanks in advance for your response.
I haven't installed my foam fairing as of yet but,...... maybe Jetguy or Rdog will chime in here and advise us that they had coordinated with "BuyPlaneParts" and are about to release another improvement with easily removable wing root fairings. Made from the same ABS material that the landing gear fairings are. I think a three piece system for each wing. One for the leading edge which overlaps two straight pieces for the top and bottom of the wing.......what do you think??
