Dwg 46, 2 1/2"
The plans show 2 1/2" for the bottom overlap, but nothing for the top. Many use the 2 1/2" to avoid pillowing. I skipped every other position making mine 5-6". The risk of spacing them that far is there might be slightly more pillowing between the screws. If your careful when you drill the fairing, it will lay flat as mine does.
