Can someone tell me if there is a rubber seal between the fuse and wing root fairing? Not mentioned in the plans but I seem to recall it on the RV-7, not that, that means anything.
There is no rubber seal for the -10, it's the only one of Van's kits without it, it's easy enough to add if you want to. I know of one other builder that added it, I believe you can buy the material from aircraft spruce direct.
