Bowed ribs
Its a common occurence to have "bowing" during the heat treat process as the metal was compressed and streched during forming. Some of my -4 ribs had 1/2 inch or more bow. The fluting (doesnt take much) between every rivet hole goes quickly once you get the knack. As mentioned, establish rivet locations and to make it simple, draw a line on the flange with a sharpie where the rivet will be. you will quickly see how the fluting moves the rib back straight as work along the flange. If you accidently over flute it, simply squeeze down the flute with hand seamers or duckbills. You will also have to do this on all the fuselage bulkheads...
