Heyco SB437-5 grommets
Bob,
I enlarged the grommet hole in all the ribs with a step drill to the next size up and ultimately installed Heyco SB437-5 grommets. I?ve run two shielded wires ? one for the nav/strobe and another for the landing lights (installed in each wing) in case the wig wag mode created noise. I also ran the Tygon tubing for the AOA plumbing.
If you are running just one shielded wire, you could easily get by with SB-437-4 grommets. Originally I was planning on using the larger bushings inboard of the stall warning micro-switch and the smaller bushings the rest of the way to the lights ?however discovered that although the two shielded cables would fit into the SB-437-4 grommets, there was a significant drag that likely would have made adjusting the rib positions during skinning tougher so I elected to use the larger grommet in all the holes. Both the SB-437-4 and SB-437-5 grommets fit the same hole so using the larger grommet was an easy choice for me.
Happy building,
