Hi Chuck...
...you'll need saw horses or similar to support the wingtips as you remove the wing attach bolts.
First, drain the fuel tanks and remove the wing root fairings. Remove the floorboards under the seats to expose the attach bolts. You'll see 16 or 17 bolts along the top of the spar and a matching number along the lower spar cap...all these have to come out, plus one 1/4" bolt attaching the rear spar to the fuselage.
Removing the flaps and ailerons is recommended, since you're shipping...wrap and store them. If there is wiring for nav/strobe/landing and taxi lights, either label and cut them or if there's a plug-in, disconnect them.
The big bolts in the center splice can be a bear to remove but squirting some penetrant will help and an impact driver, like a rivet gun on the head of the loosened nut will help while you rotate the bolt.
There is also a leading edge bolt that supports the inboard end of each fuel tank that needs unbolting.
Best,
