Wing Pushrods
I was flipping through my wing build instructions and did not see a section on the control bell crank and pushrods. Did I miss it somewhere?
I remember building two control rods and a bellcrank for each wing. I knew followed the plan when I was building them
DWG 15A
DWG 15A contains the dimensions, parts for the torque tubes and bellcrank installed in the RV 7/8 wings.
Attached
Yeah, the parts are on Drawing 15A. I was just curious if there was a corresponding section in the build manual. I can build to the drawings if I need to.
A couple lines of instructions here:
