CharlieWaffles
I'll try to get a photo, but my long j-channels are not matching up to the hole pattern in the outboard wing skins. They were drilled per the plans, with the short channel nested inside the long channel and flush with the inboard edge of the main spar. The short channels are lining up just fine. I even verified they are the correct left/right/bottom/top set up and still no go. I held the long channel up to the hole pattern on the main spar and it lines up ok (where it was drilled), but the skin pattern seems to be different. Has anyone seen this before?
