me again
I have started on wing kit, completed spar plate nuts and looking ahead at rib prep. it looks as though i need to know now and prepare for what wiring, sensors, antenas, servos etc will be in the wing. im assuming this is all to be done starting with holes in the wing ribs for conduits etc.
the instructions reference lighting wiring and Pito plumbing only.
ive seen in builders logs that they have prepared for Heated AOA Pitot masts, OAT sensor, AP servo (i think) and other equipment at wingtips etc.
i intend on the likes of a G3X Garmin EFIS, GTN650 Navigator, Autopilot, AVEO wingtips (Damien and others have convinced me their troubles are behind them) i have the standard fuel senders as i was told they can work with any set up and Vans stopped selling their capacitive version
im not even sure whats needed to be installed or prepped for at this stage to support the above. the zip tips im gathering is one conduit from root to tip.
im not sure whats needed in the wing to support the aircraft systems. do i need to buy a servo at this time and it will have instructions? same with AOA pito mast?
And what is the installation method for wiring that goes to other locations? same conduit and make a hole in the conduit to pull out wiring at that location, or seperate conduit from wing root ? any help would be appreciated. thank you in advance
