I am about to rivet my first spar/ rib assembly. Main ribs are primed and ready. The instructions don't mention but it seems it would be better to match drill the nose ribs and counter sink the front spar in the appropriate spots first. It seems like at minimum the skin/spar/rib counter sunk rivets should be counter sunk at the spar. I also think the ribs get flush riveted to the spar only under the tank.
Any suggestions on work that should/ could be done before the rib rivet?
