NorthernRV4
Working on laying out my Left wing. Ribs & angles are drilled to the Phlogiston spar. Working on drilling the main ribs to the rear spar and I realized I made an error and drilled one hole for the outermost rib that won't work with the aft flange. The blue dot is where the outer/lower hole drilled in the spar lands on the rib flange. I have two fixes in mind.
1. double up the inside of the rib flange with a 2024 5/8 x 5/8" .032" angle and disregard edge distance on the lower hole.
2. cut the flange off completely and replace it with a piece of 6061 3/4 x 3/4" .063 angle. I prefer this route since it ties into both the angle on the aileron hinge bracket and the outer plate W-414.
RV-4 Wing construction by James Soutar, on Flickr
![](/proxy.php?image=https%3A%2F%2Ffarm8.staticflickr.com%2F7639%2F26919868470_43f8869e01_c.jpg&hash=133adc12f08b216764f3155430ca682a)
![](/proxy.php?image=https%3A%2F%2Ffarm8.staticflickr.com%2F7191%2F27125877581_a25f4cded2_c.jpg&hash=a35c3683d3a2bfb642b770c473f50bca)
