Does anyone have a picture they can share of how they handled the wing conduit (the nylon corragated stuff that Van's sells) as it passes into the fuse? Do you simply cut a hole in the fuse in line with wing conduit and terminate the conduit just inside the fuse, or is it better to have the wing conduit stop nearly flush with the last inboard wing rib, and just pass the wires into the fuse?
Thanks for the help.
