I put the wing bolts in today so while attaching the center and forward fuselage for the first time. I got all the bolts in with out to much effort but it is almost like the bolts are to long or the spacers to thin. Even with the washers in place I can not tighten the bolts down as they hit the non-threaded part of the bolt.
You can see the non-threaded bolt that is still exposed once the washer is on.
The small bolts have the same problem, nothing ever tightens up.
Should I be concerned here, or is this normal with the spacers, but the wings will fix it?
thanks,
![IMG_8667.jpg](/proxy.php?image=http%3A%2F%2Frv10.trollingers.com%2Fvans_images%2FIMG_8667.jpg&hash=193f6d3ca749fc03109f9a29852fee56)
![IMG_8668.jpg](/proxy.php?image=http%3A%2F%2Frv10.trollingers.com%2Fvans_images%2FIMG_8668.jpg&hash=d6ee26ed19279b1186d2afadcbe324c1)
thanks,
