Tonight I started putting in the close-tolerance bolts in the left wing, attaching it for the final time (I used standard hardware bolts before). I have come to the conclusion that it's not physically possible to get a wrench on the bottom outside NAS-7 bolt nut in the forward gear leg support. I can get a wrench on all the top bolts no problem, and the bottom outside AN4 bolt I managed to get with only a little trouble - but no amount of cursing or banging or pushing or twisting would allow me to get a wrench on the 5/8" nut for the bottom outside NAS-7 bolt. Nothing doing, no way, no how. I'm pretty sure the bottom inside nut can be reached, and I know the bottom inside AN4 nut can be reached, but I just can't see for the life of me how to get a wrench on that bottom outside large bolt nut. I've gotten the nut started by finger quite easily - but I need hydraulic fingers to do anymore than that, and the wrench hits the gear leg support no matter how I contort myself and approach it.
Now tonight after a long hot shower and well into my second properly mixed Crown and Coke, I think I might be able to sacrifice a 5/8" wrench on the grinder and slim it down enough to fit - how did you guys do it?
