hamblin10
Active Member
Has anybody considered installing cover plates on the wing handholds at the tip? If you hangar the aircraft and do not intend to remove wings then some cover plates may help with drag by forcing the high pressure air around the tip vs going through the hand hold. At this point I'm not sure the total improvement but there will be some.
