I'm in the process of filling and block sanding the cabin top after fitting the windows. One area that seems a bit more challenging is getting a smooth, consistent surface on the built up fiberglass fairing between the windshield bottom and fuselage. I managed to get a nice 7" radius all around with the layers of glass, but after sanding out a top layer of micro, the surface is still wavy and not as smooth as some of the finished 10's I've seen. I've been using a variety of PVC pipe sections as sanding blocks, up to 6" in diameter, but still struggling. Is it just my technique or is there a better way?
