The past weekend was not good for my build. I cracked the canopy while trying to reposition before I finished a cut. So, lesson learned, never more canopy before finishing a cut, or the crack will start right at the unfinished cut.
I was so mad at this (mainly myself), but now I kind of cooled down. I am here for some help.
1) The crack on the windscreen (yes, I made the big cut) is about 5" long, right in front of the pilot so I guess I won't be able to live with it. Does anyone have a damaged canopy that the front portion is still useable?
2) After calming down, I continued working on the sliding portion of the canopy. I drilled canopy to the frame, and all went well (so far). After fitting the canopy with frame to fuselage, I found the sliding motion is not free, actually pretty tight. After some measurement, I found the canopy expanded the frame almost 1", instead of the 1/2" as commonly mentioned. Vans instruction says to re-adjust the frame. I am now very "crack sensitive". Will this much adjustment crack the canopy? I plan to adjust the frame, and countersink and enlarge the holes on canopy before fitting them together again, thinking the enlarged hole should prevent much stress around it. But I would get some opinions. I don't want to re-do the cutting, trimming, drilling again (even buying a new canopy is not that heart breaking for me after the cracked windscreen).
