Space Cadet
Does anyone know if those who had the issue with paint cracking at the rear window to fuse joints had used epoxy/micro or superfill (or equivalent) at the joint?
Wondering if I really have to put a fiberglass layer over that joint or can get by with some epoxy filler over the same spot (including the 0.75" outside edge of the window). It seems like that would accomplish the same thing - getting an "equivalent" material over the gap and the weld-on in the gap.
Thoughts?
Thoughts?
