Wig Wag Flasher Module Installation Location
apkp777
Hey all,
Any suggestions about where to install my wig wag flasher? I don't think they produce a high level of noise, but am a little reluctant to put it behind the panel. That is where I prefer to put it however. Anyone have any troubles with it installed there?
wig wag
I have my wig way mounted low on the sub panel in front of the left seat because the wig wag I used has a button on it to change the flash pattern and so I felt I need access to it. In 2.5 years and 650 hours I have yet to need to change the flash pattern. No known interference yet.
I put ours on the sub-panel. Removed the cover and screwed the cover to the panel and then glued the relay back on to the cover. Mounted the bridge just above it. Made for a clean installation.
