Pilot135pd
I was adding a pin 4 to each of my G5s today to finally connect them both to the AERA660 and I noticed that the top G5 (picture labeled G5 #1) has a "Garmin Can Terminator". The bottom G5 (picture with no label) doesn't have one of those and both harnesses have the same 9 pin connector.
I did some googling and I think it's a Garmin Can Termination Kit, 9 PIN P/N 011-02887-00 but couldn't find out why the top G5 has it and the bottom one doesn't.
Could someone give me an idea why one and not the other?
On another note, could that have anything to do with why the bottom G5, after 3 versions of new batteries, is still discharging the battery even with the circuit breaker pulled? Garmin doesn't seem to know why some still do it, could this be part of the problem? I was tempted to remove it and install it on the bottom G5 but then remembered how much these things cost and decided to better ask here.
