In the handbook, on the table for torque for AN Flared fittings, the values for Steel fittings is higher than for alum fittings (in some cases dramatically higher). Is this just because the steel can support the higher loads on the threads, or is there a reason why the steel fittings NEED a higher torque to seal reliably?
