N941WR
Legacy Member
This is not intended to be an ad but is a serious question I?ve been struggling with.
With the EICommander installed in my plane, I can look over and see exactly what the condition of the ignition is.
The unit?s TDA screen shows me that the ignitions are firing at the correct time, the current advance of each unit, and that my plugs are firing correctly (Not fouled and there is no broken leads).
TDA Screen (Typically the ignition harness graphs are all the same height, this is just a mockup.)
Since I have a fixed pitch prop, is there any legitimate reason to perform a run-up?
![TDA%252520with%252520Advance.jpg](/proxy.php?image=https%3A%2F%2Flh5.googleusercontent.com%2F-cCE4V5wxzGE%2FTIVVk71QfKI%2FAAAAAAAAAds%2F7lboxyugTys%2Fs145%2FTDA%25252520with%25252520Advance.jpg&hash=34369d6ba0948f6d89e802e6b833f2f0)
