Deciding wether to use screws or camlocs to secure top cowl of my RV7A.
Comments please, good and bad
Peter
Our 7a is all piano hinge, easy to take off, true pain to put back on. Actually dread and avoid taking the cowl off unless absolutely necessary. Our friend has camlocks and they are so much easier. Screws or camlocks, either one much easier that hinge set-up.
One of the things I do not like about the RV's is how difficult it is to take the cowl off for an inspection. Maybe I am used to the heavy latch down on the 140 I used to fly. I have always felt it was necessary to open the cowl as part of the pre-flight. I have tried to figure out how to have a better way to inspect the 9 I am building.
Anything that makes it easier to inspect the engine, I am all for.
I had similar thoughts when building my -10, and eventually copied Dave Saylor's big oil door. See www.aircraftersllc.com , go to products, then big oil door. I think this could be adapted to any of the RV's. The left side upper cowl is split at mid-cylinder 4 and the rear half hinges up. Gives a great view of the engine.
Jim Berry
RV-10
Hinges on the horizontal cowl joint and on the vertical firewall on the lower cowl. #10 SS screws, tinnermans and floating nutplates on an .063" flange along the firewall top and bottom. I did lay on one layer of glass on the inside of the cowl to thicken the cowl flange where screwed.
With a decent electric screwdriver the top cowl is off is 5 - 8 minutes, no issues. I have spare screws in case I round one out. Have replaced maybe 6 in 220 hrs.
3" spacing is probably good. Highest stress point for me is on the bottoms. Have replaced some rivets there with #6 screws and nuts to hold on the .063 mounting flange.
Would do it again that way in a heartbeat. Couldn't justify any advantage vs. the $$$ for camlocks.
screws will cause the cowl to wear from vibration. Camlocs are spring loaded.
