Which way to turn ??
daberges
Member
After all the planning and shaft marking/indexing etc. I got my prop to stop at the 10-2 position. (TMX320 - sensenich 2 blade prop). Just right if I ever have to hand prop start it. Looks (to me) good.
Unfortunately - the prop now gets in the way when I put the tow bar on. Thus after making sure mags off and master switch off etc. - I swing the prop out of the way.
Question - is it better to move the prop in the direction of normal rotation or not. One way the mags may give a spark (on the start up spring) the other way I am driving everything backwards?
Any ideas.
Turn to 9:00
Let's say you just shut down the engine by setting rpm to 1000 and did another mag test checking for grounding, then pulled the mixture and now shut off the key or better yet, shut off the mag switches and then the master.
Now you have tested the mags, closed the throttle, mixture is to cut off, key is out of the switch and the master is off. The master doesn't have anything to do with this process except keeping the battery fron going dead and cutting off the starter.
Now if the prop IS AT the 10:00 position when you are ready to connect the tow bar, then just move the prop DOWN to the 9:00 position. You will not hear a mag click!! If you do, then something is wrong!
Just a note here....... Key switches, I hate key switches. They do nothing to secure your aircraft, and they are a maint problem. When they go bad, they remain HOT MAG with the key removed!!!! When you move the key to OFF position you will notice that the key will move about 1/8" more, as the switch wears, it will become hot there!!! You just shut down the eng. with the mixture so when you shut off the key and removed it, the mags are still HOT. There is an AD out for this. I found this out way before the AD. :eek:
Warren
NEVER trust a key type mag switch!
In answer to your "which way" question, If you don't have a vacuum pump, always turn the prop backwards. Vacuum pumps don't like to be turned backwards because you are forcing the vanes against their intended travel direction.
