JoeG
Before I ask this, I will make the disclaimer that I am an engineer. I realize this can be a deficit when building this airplane (i.e. every little thing has to be perfect), but I'm making do. As Ken, at Vans, told me on another issue; "It's just an airplane. It's not any more complex than a tractor. Just build the darn thing"
So, with that caveat, here is the Question...
Question: Which side of the HS-710 and HS-714 did you put the AN470 shop heads on?
The plans and directions remind the builder that the inboard most holes are counter-sunk and that the Flush shop heads on those rivets should be on the aft side of the 702.
View AA on DWG3 shows a front view of the 710-714-702 intersection where the rivets are called out. With that and the aesthetics factor (Forward side will be visible after assembly), I'm inclined to put the 470 shop heads on the forward surface. What think you?
