I've got an IO360 with Superior forward facing cold-air sump and Bendix injection, and currently have the Magna-Flite starter on the engine. This starter does not have enough torque to reliably swing past the compression stroke with my lightweight WW200RV prop, which is a known problem for this model starter.
My question for the guys that have been there and done that - will the Skytec or B&C starter (or others) fit this configuration? I am in the process of fitting my lower cowl now, so if I need to carve on some fiberglass for clearance this is the time to find out.
