DennisRhodes
The intelli VOX portable intercom( PS Engr Aerocom III) I have used for a while now is becoming annoying with frequent open mic operations. Since the unit has no squelch control about all you can do is look for the item that's keying the mic ie vent, air leaks etc. Tried to use the built-in intercom in the IC A210 but found that the max squelch settings were still not enough. What intercom do you find that works good in the hi noise cockpits? I'm using a Zulu ll and a second good quality ANR headset in a RV 9. Don't believe mine's any louder than the rest of the fleet!
