Captain Sacto
For some odd reason, I neglected to set rivets in the outboard holes of the rear spar carrythrough (HS 609 PP) before I closed it up over a year ago.
Now I'm wondering what might be the best blind rivet to set. This is a #30 hole, and MSP 42s are strong, but they aren't long enough.
I'm considering enlarging the holes to #19s, and using BSPQ-5-4s, as these are called out inboard on the same stiffener.
My problem? If I use the BSPQs, I exceed the radius-edge distance by just a mite, as you can probably guess by the image above.
So, learned colleagues, I request your advice and suggestions.
Thanks in advance! -- Tom Parker in Sacramento
![Flying-airshow-acconst609.jpg](/proxy.php?image=http%3A%2F%2Fi108.photobucket.com%2Falbums%2Fn23%2FCaptain-Midnite%2FSummer%252009%2FFlying-airshow-acconst609.jpg&hash=edf3b9cdc0369b0fb131b7e08cd0336b)
