Fearless
What axle bolts did you use when installing the wheel pant bracket on the gear leg when mounting the axle, brake disc and pant bracket? The plans in section 35 say to use the AN4-16A's but they are too short when you use the washers as spacers to clear for the brakes. AN4-19A's or AN4-20A's? What have the consensus of builders replaced with?
