So I am doing my reading tonight and getting the proper supplies out for tomorrows work on the -12 and I am a bit confused.
On Page 09-05 Step 1 it says to "Cut 5/16 Aluminum tube to make four HS-1210 Hinge Stops per dimensions in Figure 1
The only aluminum tube I have seen appears to be one that has some pre-drilled holes and has a bend in it, so If I use this which end do I start cutting from?
Or was it a smaller piece that was in with connectors etc?
