Which AFZs series compatible with Dynon peripherals?
rvator51
Which AFS series EFIS are compatible with Dynon peripherals?
Are the 3000 or 4000 series of advanced flight systems compatable with Dynon hardware or is it only the newer series?
I have a D700 in the RV-4 and want a bigger display. I can't fit a 10" Skyview in without major rework. But I probably can fix a 8.4" AFS. Since the AFS displays are taller and have the engine instruments on the bottom, I think it would work a lot better in the RV-4. Anyone flying behinf the 8.4 AFS in a RV-4 already that could give a report on how they like it?
Only the 5000 series is compatible with the Dynon peripherals. You could go to the 7" HDX when available. Other than that your only option would be the 5500 AFS, which is a fantastic product.
