NinerBikes
The ferry that brought my plane back from the east coast had an intermittent problem with the oil pressure electric connection being loose. Somehow, in the process, he reduced the volume of the safety warnings that you hear in your head set.
For the life of me, I can't find it on the Skyview Classic to adjust. Settings for all warnings were turned on, except AOA, with volume adjusted to 100%.
Which then leads me to believe that the Skyview Classic goes through the Garmin SL-40 radio and com somehow to get into my headset, and that perhaps the adjustment is in the Garmin SL-40?
The greetings ""Dynon Skyview" in the british accent, is turned down way too low. Need to get that volume up.
I know, somehow, it would bite me if it was a snake, I'm that close to finding it.
