Pittsartist
A quick question.
I'm building an RV6 and as it evolves I'm getting a little concerned about finishing up with a rearward CG.
Here's the spec
RV6 / QB / Slider all to plans
0-320 B4B. B&C starter, B&C lightweight (8a) alternator, Bendix F.I., Bendix Mags. This is a conical "flatback" motor.
Oydessy PC680 battery, Traditional Flight instruments, Dynon EMS. Ray Allan Electric elevator trim
Composite Prop (probably the Sensenich ground adjustable one.)
Later type cowls
Not much filler, fairly lightweight paint job
Whats the prediction on empty CG ?. Should I be worried / be trying to move things forward / backward ?. Are there any quick tests (EG interim w & b calcs) that can give me a clue ?.
Any help appreciated !
Here's the spec
Later type cowls
