Wicked Stick
I'd like to query all you 8 builders out their that have gone before me. ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Where/how did you route your pitot line coming in from the left wing and more importantly how did you go through at the wing root and into the fuselage ? Did you go behind the spar and then through center section of the spar to get to the front gear tower area and then up to the panel ?
It looks like it "may" be possible to route a plastic pitot line in front of the spar, then between the front wing spar and the fuel tank, and thus avoid having to have it come out the back side of the wing spar, through the narrow space at the wing root, into the fuse and then back thru the center section spar just to get to the front of the airplaine again. (seems like the long way around)![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
What did you all do ? and if you got a good one, do you have pictures you could post. Also, what type of connector did you use to go from the 1/4 aluminum tubing to transtion it to the plastic tubing ?
