Simple question (I hope)...
Is there anything wrong with priming interior parts after assembly? Isn't the point to create a chemical/mechanical vapor barrier?
I've searched the forums and there's a lot of varied techniques for when primer is applied; before dimpling, after, etc but I don't see anything wrong with priming after riveting where you can. If the exterior will be painted, doesn't that bar water intrusion around seams and rivets?
Thoughts?
Thoughts?
