When to drill F-915 to skin?
gfb
Anything special here or just drill whenever the skin is on for the fwd longerons, etc?
Just did this early this month. These were the last holes I drilled on the side skin before doing the big dis-assembly. No particular reason it was last, probably just because I hadn't loaded my #30 bit in a while and this is what was left to do. You should be able to drill that whenever you want after the skins are on and everything is square. I do know that I didn't rivet the side seat ribs to the bottom skin until much later (this past Saturday).
On a side note, the massive dis-assembly of the entire center/forward section is the most demotivating part of the build so far. Seems like such a big step backwards - it isn't of course. Eventually you get to put it back together for good though.
Thanks FC. Yeah, I'm dreading taking it all apart. I'l make sure to drill before I do that ;)
