I am working on my RV-6A quickbuild fuselage. There have been quality control issues I stumbled on last fall with F-657 gussets installed backwards. That caused extra holes in the wrong place on the F-605 bulkhead top that thankfully did not interfere with the roll bar AN3 attach bolt holes that will be drilled soon. Vans sent new ones. Fixed it and moved on. Fine. I'm now at the front end and things didn't look right. I didn't have that little "bump out" at the top of the firewall. Why not? Anyone see why not in the 2nd photo? Answer: The F-646 ribs are installed upside down and flanges point inward instead of outward. Notice the 90 degree sub-panel. No tilt. Guess what I get to do. Drill out 36 rivets, hope to salvage the sub panel, make new sub panel attach angles with the proper degrees of tilt, etc. I suppose there aren't too many 6A quickbuild fuselages left but I thought it was a good time to remind any builder that just because you have a quickbuild doesn't mean it was built right and its up to you to know what's wrong. Kind of a bizarre dilemma for new builders, eh?
![o4K.jpg](/proxy.php?image=http%3A%2F%2Fhalie.com%2Fo4K.jpg&hash=9e863e3457448df5658420d57272916d)
![o4U.jpg](/proxy.php?image=http%3A%2F%2Fhalie.com%2Fo4U.jpg&hash=ca3316cd83ce20165ffa9796c9d99010)
