Wheel Shims
yankee-flyer
I bought some wheel shims from Van's when I bought the kit, assuming I'd need them to correct the toe-in. Never did that, so thought I'd use them to correct the camber. They are thin tapered metal wedges, and are too wide to fit between the attach bolts and do not have holes in them for bolts to pass through. How are they supposed to be used? All the planes ever said were "use shims (with part number) as needed". Confess total ignorance-- cut them down and use between Bolts? Drill holes for bolts? ????
Thanks!
Wayne120241/143WM (180 hours and about ready for new tires)
