Anyone have an RV14A nose wheel fairing problem where the two upper attach screws (in the aft fairing half) are pulled through the fairing? Seems like there is some kind of extra force acting on those screws from the metal attach bracket on the nose wheel. I’ve reinforced the area inside the fairing with an extra two layers of fiberglass and it happened a second time. Now I’m reluctant to fix it a third time until I determine the cause. None of the other fairings or even other attach points on the nose fairing are exhibiting this behavior.
