I sure would appreciate some thoughts from anyone who has added wheel pants. I finished trimming the wheel openings, to the scribe line. When I test mated the nose and tail together, I find that the size of the wheel opening in the nose, doesn?t match up with the wheel opening in the tail. In fact the bottom corners of the nose, misses reaching the bottom corners of the tail by about one quarter in on each side. I could widen the wheel opening in tail part to match, but it just seems odd.
The second issue is with using the 4 dimples in the sides, to match drill the married nose and tail, to the hefty mounting plates. I have not yet trimmed the back of the nose. It has about 1/8? of material past the scribed trim line. Yet, when I marry the two halves, and check the alignment with the drill guide dimples, I find that the dimples are already too close together to match with the mounting plates. Now, when I trim to the scribe line, this will get worse and will miss being able to use the dimples by about 3/16?
So, do I center the brace, favor the front? the back? or, does it matter???
Anyone else experience similar frustrations? Your thoughts greatly appreciated
Tom
Tom
