Yes here is the info
Van's Aircraft: (two piece wheel pants, intesection fairings)
http://www.vansaircraft.com/cgi-bin...85-336-39&browse=airframe&product=wheel-pants
Van's intersection fairing:
http://www.vansaircraft.com/cgi-bin...336-39&browse=airframe&product=inter-fairings
(NOTE: If you have not already done this notify Van's aircraft you are the new owner so they can contact you with safety info if needed. I also recommend you get a subscription to the 5 times a year news letter called "The RVator" for important info you don't find on the web. In the future maybe they will do internet service of the news letter. Van's new wheel fairings are large round jobs, so I call them balloon wheel pants but they do work.)
Team Rocket:
http://www.teamrocketaircraft.com/TeamRocketAircraftcgi/hazel.exe
(Select fiberglass from the drop down menu of Product Category: and hit begain search: select the detail button for the item you want:
[TRGF] Team Rocket Gearleg Fairings
[TRGIFRV6] Team Rocket RV6 Gearleg Intersection Fairings
[TRGIFRV6A] Team Rocket RV6A/7A/8A/9A Gearleg Intersection Fairings
[TRWP] Rocket Wheel Pants
James Aircraft: (wheel pants)
http://www.jamesaircraft.com/South_Shop.html
Light Speed Engineering: (wheel pants like James Aircraft but more expensive)
http://www.lightspeedengineering.com/Services/WheelFairings.htm
TRACY SAYLOR 805-933-8225
[email protected] FIBERGLASS RV GEAR LEG FAIRINGS, LEFT HAND THROTTLES FOR RV6/6A AND HOT TIPS LIGHT KIT & POWELL'S PREMIUM RV PRODUCTS (TRACY SAYLOR'S DAUGHTER) 541-258-3885 GEAR LEG FAIRINGS (Tracy's daughter makes the product and does a nice job. Their fiberglass gear leg fairings are wider than Van's stock units but not as wide as the Team Rocket gear leg fairings, so they are a happy middle of the road. The bad part is you are not going to find the off the shelf intersection fairings will fit. However since you hae the Van's new style fiberglass gear leg fairing I would stay with that.)
Aero-Strategies Unlimited: (Intersection fairings)
http://aerosu.com/part3.htm
(Intersection fairings that work with Van's part, guess they will not work as well with rocket gear legs or other wheel pants)
Fairings Etc
http://www.fairings-etc.com
http://www.fairings-etc.com/gear leg, wheel pant, nose gear.htm
I might suggest you go with the whole Van's package for ease of installation. Van's pants include all parts and installation hardware for two main wheels. One advantage of using Van's wheel pants is the hardware/brackets, where the "other" go fast fairings come with brackets. However the Van's bracket can be modified to work with the other style fairings. It might be easier to go with all Van's parts, wheel pants, intersesction fairing and brackets.
Have Fun, fly safe. George
