Actually, it's a pretty common bearing size. The reason they are so expensive is the 'tolerance' (very tight on the actual part number used). You can buy the same bearing (one notch poorer in tolerance) from your local NAPA auto parts store, & it will work. If memory serves, the only difference is the last digit or two in the part numbers.
Charlie
