I am about to assemble the main whesls for my 9A, and when I pulled out the tubes, I noticed that there were two threaded portions on the valve stem, one near the tip, and another up near the tube. I am assuming that the nut near the tip off the stem goes on the inside of the wheel half with the hole for the valve stem, but I was not sure where the other nut and 'washer (not sure if it is really called a washer)' get located. Do both the nut and 'washer'go on the outside of the wheel, or does the nut go on the inside, and the 'washer' go on the outside?
Thanks!
Ron
RV-9A 90965
Thanks!
Ron
RV-9A 90965
