Is it better for the engine to have it at a particular RPM? Just curious, b/c Mike Seager suggested to me that, for the RV-9, I get the rpm down as low as possible to reduce float. 500s or lower is what I seem to remember him recommending.I like to see around 600-650 when hot.
So it's primarily determined by engine smoothness? And when should the rpm be set? When the engine is cold or warm?Anything less than around 600 and most engines start to run rough, you also risk the engine quiting at an inopportune time if the RPM gets to low, most folks don't like that.
Just wondering what to expect with my Catto prop.
Here's my rationale: On the ground, taxiing around, you don't have to close the throttle unless you want to. You can idle at 700, or 800 if you wish. But in flight, just because you close the throttle, it doesn't mean you will idle at 450. The forward airspeed will speed the prop up. You will float a lot less with a low idle speed set. Then, at the end of your rollout, you just open the throttle a bit, and idle at your desired RPM.
Bob actually at idle you have very low manifold pressure, ergo you get max ign timing (advance). Seems counter intuitive but that's how it works. At high MP it will retard back to base timing, probably 25, then as you climb and or reduce throttle it will beging to advance.
This is one of the (false) reasons why people are so impressed with EI. They are great, but the smooth idle comes primarily from the ign timing, not the more powerful spark. If you were able to set a pair of slicks at 35-40 you probably would not be able to tell the difference at idle.
Tim
Vlad:Interested in ###. After 314 hours on factory new O-320 the idle became 350 rpm. It seemed kind of low to me and I turned the screw in about half turn. Now it's high. What are yours on idle? Explain why if you will.
If so, you might need to look around and see if something is loose or fouled. Getting too much air,.. not getting spark,... etc.
Unless you know the idle setting moved,...
Vlad:
The O-320 should have the idle set at 550 to 650 RPM as per Lycoming. I doubt it the engine will run at 350 RPM. If it is running there check your Tach. There is a slight difference in idle between planes due to airflow. BUT! not as much as what you are seeing.
Barry
http://www.lycoming.com/support/tips-advice/key-reprints/pdfs/Key%20Operations.pdf
By the recommendations of Lycoming, see link above, you should not let the engine idle below 1,000 RPM after start. I have heard that this also helps in avoiding premature lifter wear and since I'm running an H2AD engine I have tried to follow this recommendation. I have a wood prop and my actual low idle setting is approx 700 RPM, but I try not to let it idle there very often.
I know that this idle speed may be controversial, it is just what I try to follow based on Lycoming recommendations.
I know a another concern with this practice will be excessive brake wear, but I have close to 200 hours on my plane with the original brake pads, which still have plenty of wear left in them based on my inspection 2 months ago.
